Service mode for image runner 2020
  • romnick
    • Aug 2008
    • 56
    sir, i am a Ricoh technician, but unfortunately i encountered canon copier in our project and the copy is very light. id like to adjust copy quality but i don't know how to enter into service mode so that i can adjust image density or the value of charge current,bias as well as toner drop adjustment. I need help please. Thank you in advance!
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: Service mode for image runner 2020
    Light copy? What about print? Need to locate issue.Can be a scanner,toner,developer...
    • romnick
      • Aug 2008
      • 56
      Sir, machine is full of toner and present copy counter is 10,000 copies only that's why i'd like to adjust first the bias, or charge current but don't know to open service mode.
      • zoraldinho
        • Mar 2008
        • 5007
        I can sand you complete service manual but for toner dropping,bias is not the reason i believe.First clean complete machine,observe and find the problem.
        • romnick
          • Aug 2008
          • 56
          Sir, i am not asking service manual but howto go to service mode.
          • teckat
            • 16083
            READ>>>iR2016-2020 _SERVICE MODE-.pdf
            Additional functions key(User Mode key) > #2 key > #8 key > Additional functions key(User Mode key)
            do not hold down the 2 & 8 key together
            • zoraldinho
              • Mar 2008
              • 5007
              Good luck with service mode.
              • romnick
                • Aug 2008
                • 56
                Thank you teckat, for giving me enough information. thank you again!
                • teckat
                  • 16083
                  thanks !!!
                  Be careful what u do in service mode/
                  no experience can lead to expanded issues
