Image fading
  • bineshpaul
    • Jul 2010
    • 43
    Image fading
    Dear All
    I am encounted a problem with image fading. Upper part of the paper is fading at the same time below side is OK. When is changed the Drum & Cleaning blade, first 500 pages is ok after the same problem facing. Scanned image of the print is attached herewith. Pls support me. Thanks in advance.
  • bk59
    Re: Image fading
    Check your transfer roller. MAKE SURE the the white clips are installed. And right below the clips are two metal brakets. Make sure they are not bent.Try a new trans roller. Bill
