Tonner Spreading IR3045
  • bineshpaul
    • Jul 2010
    • 43
    Hi,
    I am facing another problem with Tonner spreading In IR3045 Machine. pls help me. the plain copy is attached herewith.
    Regards
    binesh
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5011
    Re: Tonner Spreading IR3045
    Open fixing assy. and check preasure roller and fixing film.Is this the same printer from previous post? Genuine toner? Developer blade?
    • bk59
      Check your drum and dev. looks like something is stuck to one of them Bill
      • montana
        • Aug 2008
        • 392
        hi.....replace the drum cartridge.........
        • CopierChick
          • Aug 2012
          • 85
          Did you get this fixed? I am having similar issue and wondered if I should replace the drum also.
          • SCREWTAPE
            East Coast Imaging
            • 3396
            Are these copies off the glass.
            Are these internal test pages or prints.
            Have you tried PG4 (blank) test pages to determined whether its the drum of fixing.
