iRC4080i image quality
  • MFPTech
    • 486
    Hi,
    Have been dealing with an intermittent quality issue and tried new drums and ITB without success.
    Test patterns 11 , 18 and 20 are attached. The arrow points the leading edge.
    Any ideas please?
    Thanks in advance!
    iRC4080i.pdf
  • vigour
    • Aug 2010
    • 1038
    Re: iRC4080i image quality
    can you double check if you are pointing to the lead edge.
    Can you post PG10 and check PG5 with each colour separately.
    • MFPTech
      • 486
      That's the leading edge. Confirmed by jamming the copier while printing the test page. All the other Patterns look good. 11 and 18 were the only ones that are obvious.
      • vigour
        • Aug 2010
        • 1038
        My guess would be cleaning blade, or some weird digital effect.
        when would it show up on the customers copy?
        because it only shows up at the sreas with high density process black.
        • teckat
          • 16083
          who even uses those test pages ???
          Print out a PG6 GRID PATTERN --WITH FOUR COLOR
          Print out a PG6 GRID OF THE SINGLE COLORS
          POST THEM HERE
