MF9170 ERROR CODE E194
  • zoraldinho
    replied
    Re: MF9170 ERROR CODE E194
    E194 Error in CPR sensor
    Description
    Cannot detect color displacement detection pattern, detected results fall outside the
    acceptable range.
    Cause
    Dirty color displacement detection sensor, color displacement detection sensor fault,
    DC controller PCB assembly fault, toner cartridge fault.
    - Replace ETB unit
    - Terminal assembly fault (check on every contact between the
    terminals of each color and the high voltage PCB assembly)
    - Replace DC controller PCB
    - Replace toner cartridge
  • nasertop
    started a topic MF9170 ERROR CODE E194
    For mf9170 error code e194 . What is the error details? Is it ccd or fixing ? I have no service manual for this model. Please help me. Thanks.
