ir 5185i can use fiery?
  • DANIELCANON
    • Jun 2011
    • 187
    Es posible acondicionarle fiery a una irc 5185i; ya que noto que esta maquina no cuenta con salida para el cable de comunicacion con el fiery.
  • vigour
    • Aug 2010
    • 1038
    Re: ir 5185i can use fiery?
    YES with a kit
    see brlow
    http://www.copytechnet.com/forums/ca...185-5185i.html
    • HELIO240
      • Jan 2011
      • 137
      Yes.remember of the make a change in the service mode copier>option>intface to 4.
      the life is good so enjoy .
      • teckat
        • 16076
        believe u mean set to "3" for H1
        Converting an 'i' model to use an imagePASS H1 v2
        After setting IMG-CONT to 3,
        Amd powering down and installing the Open Interface PCB and booting back up, the unit should automatically disable the UFRII / PCL Print Kit-H1, recognize the imagePASS H1 v2.0 and be completely compatible.
        ****In some cases, an additional step is needed.
        An MNCON Clear may be required to complete the installation, ONLY IF U HAVE ISSUES WITH INSTALL
        In order to connect the Fiery to its supported 'i' model copier, you will need to order the appropriate Open Interface Board.
        OPEN INTERFACE BOARD - 8408A004AA
        * Please be aware that all imageRUNNER devices involved must be at the latest version system software for this to work. In addition, when connected to the imagePASS/ColorPASS, you will not be able to use the internal Canon UFRII/PCL printer kit.
          • 2619
          If you get a "please wait" message that does not go away an MMI clear may be needed. print out user data lists first.
          • teckat
            • 16076
            MMI clear will not do it> u would need to do the MNCON clear/ hopefully not
            been thru this issue of converting many times on this model
            • KenB
              Geek Extraordinaire
              • Dec 2007
              • 3941
              Don't forget the crossover and interface cables. They tend to get separated from the Firies during storage and shipment.
              (Since you are asking about an H1, and it's no longer current, it's a safe assumption that the Fiery is either used and/or has been in storage for a long time.)
              While you can get a crossover cable very easily, the same can't be said for the "SCSI-like" interface cable.
              O...
              No te olvides deloscables cruzadosy la interfaz.Ellostienden asepararse de lasFiriesdurante el almacenamiento y
              (preguntando acerca deun H1, yya no esactual, esel Fierybienutilizado y / oha estado almacenadodurante mucho tiempo.)
              Mientras queusted puede conseguirun cable cruzadocon mucha facilidad,lo mismo no puededecirse de la"SCSI-como"cable de interfaz.
              • teckat
                • 16076
                Belkin Crossover cable - CAT 5e - RJ-45 - M - Unshielded twisted pair (UTP) 25 ft
                http://en.wikipedia.org/wiki/Ethernet_crossover_cable
                • DANIELCANON
                  • Jun 2011
                  • 187
                  ok, y como solicito dicha interface, cual es el codigo:
                  OPEN INTERFACE BOARD - 8408A004AA ?.
                  • teckat
                    • 16076
                    • DANIELCANON
                      • Jun 2011
                      • 187
                      OK. cuento con la tarjeta de interface abierta; pero al momento de instalar dicha tarjeta encuentro otra en el zocalo donde deberia de estar.
                      que hago con esta otra tarjeta y en que influye:2012-06-07 14.42.39.jpg2012-06-07 14.57.05.jpg
                      • teckat
                        • 16076
                        que hago con esta otra tarjeta y en que influye:[ATTACH=CONFIG]16251[/ATTACH][ATTACH=CONFIG]16252[/ATTACH]
                        To connect the imagePASS H1 or ColorPASS GX100 to an iR C4080i / C4580i / C5180i / C5185i, order:
                        Para conectar el imagePASS H1 o ColorPASS GX100 con un C4080i iR / C4580i / C5180i / C5185i, para:
                        ABIERTA LA JUNTA DE INTERFAZ - 8408A004AA
                        After setting IMG-CONT to 3, powering down and installing the Open Interface PCB and booting back up, the unit should automatically disable the UFRII / PCL Print Kit-H1, recognize the imagePASS H1 v2.0 and be completely compatible. In some cases, an additional step is needed.
                        • DANIELCANON
                          • Jun 2011
                          • 187
                          ok. pero que hago con esta tarjeta ? la retiro de la maquina?Click image for larger version. Name2012-06-07 14.57.05.jpg
                          • teckat
                            • 16076
                            ok. pero que hago con esta tarjeta ? la retiro de la maquina?[ATTACH=CONFIG]16268[/ATTACH]
                            • DANIELCANON
                              • Jun 2011
                              • 187
                              that card is located in the socket where I will place the open interface .
