Canon IR 5050 U Send in trial mode?
  • Beingcre8tive
    • Aug 2011
    • 2
    I'm an independent tech and work on Canon occasionally. I've never had a problem going into additional functions and erasing a users data but this time I did it on a Canon IR 5050n and it put the universal send into a trial version. Is there any way to get it back out of the trial version? The equipment is not owned by the original purchaser who bought the license and there is no paperwork.
    Thanks for your help!
  • teckat
    • 16083
    Re: Canon IR 5050 U Send in trial mode?
    Sorry, but if u have no records of License - u are out of Luck
    Send function is available only if the optional Universal Send Kit is activated by registering a license key.
    Initialize All Data/Settings' Option/
    is that what u did ???
    WARNING: DATA WILL BE ERASED. Before using the 'Initialize All Data/Settings' feature, make sure that the data you are erasing is completely unnecessary or is backed up. Canon will not be liable for any damages resulting from the loss of data.
    The 'Initialize All Data/Settings' feature will erase the following data that is stored in the machine:
    - Data stored in in-boxes
    - Address Book data
    - Scan settings registered for the Sending function
    - Mode Memory settings registered for the Copy or Mail Box function
    - MEAP applications and
    Licenses
    - Data saved from MEAP applications
    - The password for MEAP SMS login services reverts back to the default
    - Registered SDL (Simple Device Login) user authentication information
    - User authentication information registered in the local device authentication system of SSO (Single Sign-on)
    - Unsent documents (Reserved documents and documents set with the Delayed Send Mode)
    - Job History
    - Additional Function settings
    - Image forms registered for the Form Composition mode
    - Registered forwarding settings
    Key pair and server Certificate settings registered in Certificate Settings in TCP/IP Settings
    It is not normally necessary to use this feature, but it is useful for erasing personal or confidential information when returning or disposing of the machine.
    To use this feature:
    1. Press Additional Functions.
    2. Choose System Settings.
    3. Scroll down and look for 'Initialize All Data/Settings'.
    4. Hit Yes.
