How to turn off receiving fax on IR3030
  • Alex ahir
    • May 2012
    • 125
    i want to turn off receiving fax on my canon IR3030
    how to do that??
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Re: How to turn off receiving fax on IR3030
    On main screen in status monitor.
    • Alex ahir
      • May 2012
      • 125
      but i didnt find any option
      can you plz tell me where is it exactly? i check on the sys. moniter,fax,receving fax it is on auto mode how to do manual mode?
      • teckat
        • 16083
        how to do that??
        Press (Additional Functions)[Communications Settings]
        [RX Settings] under <Common Settings>
        From the RUI, take the following steps:
        1) Click on Job Status.
        2) Select Receive Fax Job.
        3) Click Receive Mode (this is in the upper right hand corner).
        4) Select Memory Lock.
        5) You will then be asked to enter a memory lock password. Enter the password.
        6) You will then be given the option turn memory lock on or off.
        ONCE MEMORY LOCK IS ENABLED, NO FAXES WILL PRINTED UNTIL IT IS TURNED BACK OFF.
        or--
        1. Press ADDITIONAL FUNCTIONS
        2. Select SYSTEM SETTINGS (login if needed)
        3. Select STORE/PRINT WHEN FORWARDING
        4. Select PRINT IMAGE (make the desired selection)
        ON [default]
        FOR ERROR ONLY (the received documents would only if the forwarding condition fails)
        OFF (the received documents will never print no matter what)
        5. Select OK
        • zoraldinho
          • Mar 2008
          • 5018
          On the main creen click on special features and find the recieving fax.
          Do you wont to delete one recieving fax or permanently turn off?
          • Alex ahir
            • May 2012
            • 125
            [ATTACH=CONFIG]16054[/ATTACH]
            Permanent off
            • zoraldinho
              • Mar 2008
              • 5018
              Permanent off
              Read Tackat post.
              • Alex ahir
                • May 2012
                • 125
                i have 2 IR3030 both are installed at 1 location, both have a fax on them and there is only one fax line which connected to them. now i want to do send/received fax on 1 copier and on 2 i just want to send a fax only not receiving.
                i check from RUI there is no receive mode on fax received job
                • zoraldinho
                  • Mar 2008
                  • 5018
                  Check in communication settings:TX,RX. Read Teckat's post slowly.
                  • teckat
                    • 16083
                    In order to be able to receive Fax/I-fax documents in memory, you must set Use Fax
                    Memory Lock or Use I-fax Memory Lock in Memory RX Inbox Settings (from the
                    Additional Functions screen) to 'On'.
                    The Remote UI
                    • vigour
                      • Aug 2010
                      • 1038
                      Splitters on a fax line is a bad idea.
                      • vigour
                        • Aug 2010
                        • 1038
                        service mode
                        Fax
                        NCU
                        SpecialB
                        highlight SW27
                        Highlight Bit 7
                        change bit 7 from 0 to 1
                        Power cycle the machine
                        System monitor
                        Fax
                        Received Job Status folder
                        Select Manual RX
                        press DONE
                        • Alex ahir
                          • May 2012
                          • 125
                          Thanks guys for your thread,
                          see i did turn off fax receiving from service mode, NCU Auto RX i make it 99 so now copier is not receiving any faxes.
                          • vigour
                            • Aug 2010
                            • 1038
                            that changes the ring count before it answers. good if it works for you.
                            • jacky_kuo
                              • Aug 2011
                              • 54
