As Canon now distribute the former OCE Varioprint line, i think, here is the right place to post, if this should be not the case, some admin please move my post to the right direction. We have installed a Variopress110 at customers side and soon ran into problems. If you print "normal formats" like A3 or SRA3 all is fine and working. As soon as you try to work with custom formats, here per example 315x440, things went weird... the pre look screen in the acrobat (acrobat pro 9) window went partially grey, and sure enough, the box prints only a part of the document, even if all settings like document format and media formt are set correctly, in addition you can see, that in the pre print window the mesures of length and heigh are interchanged. I assume a driver issue, Canon PHD is involved. Someone else here, who has run in similar problems and can enlighten me?
Thanks in advance
Ps.: Manuals4U: YES i am trained and YES, i have a Manual
Thanks in advance
