iRAD4025/ 4035/ 4045/ 4051--Countermeasure for Jams Caused by Excessive Curl in Paper
  • teckat
    • 16092
    [Jamming] iRAD4025/ 4035/ 4045/ 4051--Countermeasure for Jams Caused by Excessive Curl in Paper
    imageRUNNER ADVANCE 4025/ 4035/ 4045/ 4051
    Countermeasure Against Jams Caused by Excessive Curl in the Paper
    Jams may occur when paper with excessive moisture passes through the fixing unit; the heat in the fixing
    unit causes the paper to curl causing a jam.
    SEE JAM LIST & SERVICING PROCEDURE PDF
    >>TP12.pdf
  • fchu5959
    Field Engineer
    • Jun 2010
    • 100
    Re: iRAD4025/ 4035/ 4045/ 4051--Countermeasure for Jams Caused by Excessive Curl in P
    Hi,
    Thanks Teckat for that bulletin.
    I just come from a 1day training on this series but no mention was made upon this issue.
    Canon Inc is really months ahead of Canon Europe!
    cheers
    • vigour
      • Aug 2010
      • 1034
      good to know
      • aodtech
        • 194
        I hope this will apply to the C2020/2030 machines as well. As the weather gets hot and humidity sets in, I am dreading getting the jamming/curling calls on these machines. Especially the ones with the internal finisher.
