IR 1018 jamming
  • Tlemsani
    • May 2012
    • 17
    [Jamming] IR 1018 jamming
    Hi every one,
    A Canon IR1018 complitely messed-up with toner ink was printing blurred copied, I opened and cleaned the toner mess (Not all of it apparently),
    now it shows a message witch tells you to open the right of because of paper jamming,
    of course it's a false jamming, I disassembled and cleaned one of the sensors (I've been told it has two of them),
    still the same message, I guess I have to clean the second one, will do it tomorrow with God willing,
    I'll let you know,
    peace be with you!
  • Tlemsani
    • May 2012
    • 17
    Re: IR 1018 jamming
    Originally posted by Tlemsani
    .......I guess I have to clean the second one, will do it tomorrow with God willing,
    I'll let you know,
    peace be with you!
    Did so but nothing changed, still the same message..
    any suggestions ??
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 4955
      Re: IR 1018 jamming
      Jam code??
      Practice makes perfect
      If you want something done right, you have to do it yourself
      • Tlemsani
        • May 2012
        • 17
        Re: IR 1018 jamming
        Originally posted by zoraldinho
        Jam code??
        To know the jam code, you should be able to print I guess,
        is that right?
        if yes, I dont have this possibility....
        • teckat
          • 16092
          Re: IR 1018 jamming
          is that right?
          jam code is looked up in service mode/ guess u are not a tech/
          toner mess+dirty sensors+blurred copies= poor printer maintenance
          call for service / before u mess things up any further
          • zaza
            MECANOGRAPHE
            • Mar 2008
            • 1095
            Re: IR 1018 jamming
            is that right?
            BEST TECHNICIAN . NICE PEOPLE .
            • Tlemsani
              • May 2012
              • 17
              Re: IR 1018 jamming
              I'm in my way to be a tech, I'm being trained the algerien way
              so your answers would help me to be one (a good one),
              this machine is messed because the onwer tried to clean it with pneumatic (underpressure air),
              thanks!
              • teckat
                • 16092
                Re: IR 1018 jamming
                thanks!
                wish u luck !!!!!!!!
                u have a mess when someone starts blasting canned air inside a printer>
                u need to gut the printer & clean / inspect all sensors
                • Tlemsani
                  • May 2012
                  • 17
                  Re: IR 1018 jamming
