my canon IRC 3220 problem is machine sometimes panel blank when print and no copy come out. when i switch off and on machine again sometime ok. but after use it again same problem will appear.. can i know which parts have a problem?
Irc 3220 panel blank
Re: Irc 3220 panel blank
on power off/always follow shut down procedure on control panel
open back of printer/
remove memory dimms/
clean ends/
re-seat/
power up/**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
Hello , i know this threat is an older one but i have the same issue.. i have already reseat the Ram but still same issue.. any new information about this? thanks MichaelMy profile is not working at the moment. The profile you see is not mine. Board redirects to a wrong userprofile. So you CAN´T REACH ME over the profile via SEND PRIVATE MESSAGE and even not over regular Email too
You only can contact me if you click my name on a post and select PRIVATE MESSAGE straight from there.Comment
hm... where are all the canon technicians? it would be really nice to get help... thanks michaelMy profile is not working at the moment. The profile you see is not mine. Board redirects to a wrong userprofile. So you CAN´T REACH ME over the profile via SEND PRIVATE MESSAGE and even not over regular Email too
hello, at some point it seems to me that I had that problem, in one machine the problem was in the accessory connectors (paper feed trays and the adf) in that connection set associated with the duplex motor, I chose to disable the duplex.
Blank screen is also related to the main mainboard, RAM or SDRAM memory of the mainboard.
Regards.Comment
Hello, i reseat the memory, cards , reconnect hdd. The panel goes not off but went to orange red without any information on it. This is not always at same time or same job.My profile is not working at the moment. The profile you see is not mine. Board redirects to a wrong userprofile. So you CAN´T REACH ME over the profile via SEND PRIVATE MESSAGE and even not over regular Email too
Hello, won't it tell you any error code? I recommend you check the sensor that detects when you close the fixing unit block, the sensor is close to the fifaction unit drawer (in the same machine not in the fixing unit) it is very likely that this sensor is full of dust, to find the sensor you would have to disassemble the part of the inverter door.
If that does not solve it, maybe it is already a problem with the power supply.
Regards.Comment
Regards.
only one time it show a code about the magenta drum this i change.
normaly the display have same color like it display errors but there is no information displayed...Attached FilesMy profile is not working at the moment. The profile you see is not mine. Board redirects to a wrong userprofile. So you CAN´T REACH ME over the profile via SEND PRIVATE MESSAGE and even not over regular Email too
