canon dr-9080c need part number for plastic/rubber feet.
  • tnr
    • Aug 2025
    [Misc] canon dr-9080c need part number for plastic/rubber feet.
    hello
    was wondering if anybody can give me the canon part number for the black plastic feet for the canon dr-9080c scanner. i need qty 2.
    i do not have the service manual for this scanner so i can not look up the part number.
    also need to find the total scan count on this scanner. anybody how to get the scan count?
    thanks in advance for any help.
    thanks
    tim
  • teckat
    • 16083
    Re: canon dr-9080c need part number for plastic/rubber feet.
    Originally posted by tnr
    hello
    thanks
    tim
    Hard Counter-is an OPTION , I believe
    The hard counter is a seven digit counter that is installed inside the upper scanner. It keeps a tally of the pages that are fed through the scanner.
    XH9-0118-000 // Black Foot Quantity -4
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5017
      • teckat
        • 16083
        Originally posted by zoraldinho
        [ATTACH=CONFIG]16113[/ATTACH]
        be careful >>>> that clears the roller count>
        misleading if u are not replacing rollers
        • tnr
          hello
          thanks for the part number for the feet.
          i think that there is a electronic count of the total scans, that is what i am after.
          thanks
          tim
          [ATTACH=CONFIG]16106[/ATTACH]
          • KenB
            Geek Extraordinaire
            • Dec 2007
            • 3944
            If you have the CDs that came with the scanner, there is a service program (that installs on your PC) that will give you all the info you need, along with the ability to make a multitude of adjustments. (At least according to the manual, anyway.)
            I very much doubt that Canon would post it on their public site.
            Hopefully you can find it somewhere out there.
            • zoraldinho
              • Mar 2008
              • 5017
              • tnr
                thanks everybody for your help.
                i will have to find the service program somewhere.
                tim
                [ATTACH=CONFIG]16120[/ATTACH]
                • zoraldinho
                  • Mar 2008
                  • 5017
                  You are welcome.Good luck.
                  • teckat
                    • 16083
                    tim
                    imageFORMULA DR-9080C Color Production Scanner
                    DR-6080/7580/9080C firmware Version 3.16 for Windows 2000, XP, Vista and Windows 7. Note: Extract this file and please carefully read the READMEFIRST.PDF document before proceeding with the firmware upgrade.
                    click on link below---
                    Canon U.S.A. : Support & Drivers : imageFORMULA DR-9080C Color Production Scanner
