canon IRC 4580 Error Code
  • hknwbec
    • 214
    hI, how to fix the error code E007-0001 and E007-0211 if we don't replace the fixing unit. any parts can be change or repair.thanks
  • teckat
    • 16083
    Re: canon IRC 4580 Error Code
    u can try procedure in pdf>
    Procedure to Put the Displaced Fixing and Pressure Belts Back into Place-
    E007-0001_0002 Fix Procedure.pdf
    don't waste time on unit if old or heavy use>>>
    Replace it>
    & don't forget to do the following after replacement & power on
    Adjustment of Fixing Assembly:
    1) Enter the Service mode. Select COPIER > FUNCTION > FIXING > FX-UHP-S > OK
    2) Check that 'FX-UHP-S is OK. This will take approximately 5 minutes.
    3) Enter the Service mode. Select COPIER > FUNCTION > FIXING > FX-LHP-S > OK
    4) Check that 'FX- LHP -S is OK. This will take approximately 5 minutes.
    ++ clear this counter >>COPIER > FUNCTION > DRBL-1 > FX-BLT-U)
