ir1670f
  • copicatt
    • Nov 2008
    • 366
    ir1670f
    Prints and reports are fine. Copies have very dark background. Optics are clean. Suggestions?? Thanks! CCD? Cable???? Common problem?? Not that I've seen!
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5013
    Re: ir1670f
    Contact Sensor LED Intensity Auto Adjustment
    Before starting adjustment, verify that there is nothing
    on the copyboard glass. Also verify that the ADF
    (copyboard cover) is securely closed.
    Execute auto adjustment of the contact sensor LED
    intensity as follows:
    1) Press the Additional Functions key and the # key to
    start service mode.
    2) Press the Left/Right Arrow key so that 'TEST
    MODE' is indicated.
    3) Press the OK key.
    4) Press '2' on the keypad so that 'TEST MODE' is
    indicated.
    5) Press '7' on the keypad to clear the CCD parameter.
    6) Press the Stop key to return to 'TEST MODE'.
    7) Press '2' on the keypad so that '2: CCD TEST' is
    indicated.
    8) Press '8' on the keypad so that the machine starts
    contact sensor LED intensity auto adjustment.
    9) End the work when the LCD indicates 'OK'; if it
    indicates 'NG', on the other hand, start over.
    10) Press the Stop key and the Additional Functions
    key (to end TEST MODE).
    If this not help,post a sample please.
