Printing error in IR2420
  • mkc1127
    • Sep 2024
    [Misc] Printing error in IR2420
    i am having a machine,model IR2420,is some times not printing.if you restarts the machine,the same print comes out.We have alredy upgraded firmware.
    pls suggest,if you are having any solution.
  • montana
    • Aug 2008
    • 393
    Re: Printing error in IR2420
    hi.....i suggest to clear the memory in service mode...
    • mkc1127
      This is intermitent problem & memory clear is alredy done
      • KL568
        _
        • Feb 2011
        • 324
        Hi,
        Any chance that your iR2420 IP address is also being assigned to a PC or laptop? Try perform ping with "-t" then walk back to copier to unplug network cable.
        • mkc1127
          Yes, i have already checked it by using PING tool.It is not used by any other device
          • bineeshgeorge
            • Jul 2009
            • 107
            It may USB cable related problem..........
