We have a 5185 that was working great all of a sudden the docs started coming out blurred. Internal prints, print jobs and copy jobs all come out blurred. i have replaced transfer assembly, all drums and fuser assembly. When i print out the gradation adjustment sheets there are no crisp lines and the colors are not solid. Any ideas? Thanks everyone
ir c5185 print and copy quality problem
Re: ir c5185 print and copy quality problem
Try these :
1 - Go to level 2 in service mode , Function , Clear , RegClear. Then sw/off/on. If no good
2 - Level 2 Again Function , laser then highlight the colour and ok. This will put lasers back at default. sw/on/off.
3 - Do a P print and then open front door and do a DC Con Dump , then re-imput the laser and registration settings back in.
If all of the above doesn't work there is a manual set up for the lasers but normally if the whole ITB and drums have been done this should put back to spec. Check your running v3 firmware, at least 93 on the MN.
good luckOh...... I can't copy at the moment then ? !!!!!! -
Try these :
good luckComment
