Ir 2570 print out problem
  • tlkk2002
    • Jul 2025
    [Misc] Ir 2570 print out problem
    Dear All,
    Any one know what is the problem of the printer?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: Ir 2570 print out problem
    What tipe of print is this? A4,A3.LTR,A4R........
    • jacky_kuo
      • Aug 2011
      • 54
      Drum unit
      • tlkk2002
        Thank you. Both A4 and A3 printed out like that.
        • tlkk2002
          So do i need to change the drum unit?
          • Paul 75
            • Oct 2008
            • 97
            Same as the other posts. Change the drum and the ITB cleaner blade. Don't forget to clean the patch sensor above the drum !
            Oh...... I can't copy at the moment then ? !!!!!!
            • teguhkarya
              This is what you have to do
              1. Change the wire (all)
              2. Clear drum unit
              3. Take out all the toner inside devoloping
              • Paul 75
                • Oct 2008
                • 97
                Thanks Canon Tec...... my thoughts exactly
                • Alex ahir
                  • May 2012
                  • 125
                  Chang the drum my friend
                  • tlkk2002
                    Dear All,
                    Thank you for your help, i will try to change the drum unit first.
                    Thanks All.
