IPF610 E196-404E
  • ras63
    • Jun 2012
    • 3
    [Error Code] IPF610 E196-404E
    I have a customer IPF610 that the user called for print head temp error. When tech arrived and re-set the printer, it came up with message to close top cover, even though it was closed. At some point the error E196-404E started and I do not find reference to it in the manual.
    I have replaced the main board with a known good one, and now, THAT board displays the same error. I have used the L Printer Service tool to flash / upgrade the firmware to 1.41 without success.
    I now have two printers down due to this error and I do not know what it means and I don't want to order a new main PCB only to have something cause IT to fail.
    Any suggestions or assistance would be greatly appreciated.
    Ras
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 4999
    Re: IPF610 E196-404E
    ERROR E196-404E
    An EEPROM read/ write error has been
    detected in the controller portion of the
    firmware.
    ①Start in
    download mode
    to upgrade the
    firmware.
    ②Start in service
    mode to clear
    the error.
    ③Replace the
    main PCB.
    • ras63
      • Jun 2012
      • 3
      Thank you zoraldinho for the reply, however, I have already forced update the Fimrware to 1.41 (from 1.40) and the error will not allow me to get into service mode at all. I can get the "S" to display in the upper right corner of the display, but the message LED lights up and it will not let me proceed any further.
      Again, I have placed a known good board into the machine and it seems to have corrupted it as well. I nnow have two main boards with the same symptoms.
      Is there a way to do a hard re-set of the main board (shorting pins) or key combination?
      Thanks for the assistance.
      Ras
      • zoraldinho
        • Mar 2008
        • 4999
        Did you folow the PCB replacement mode in special mode?If you are not,you have eeprom conflict.
        Special Mode
        This printer supports the following special modes in addition to the service mode:
        - PCB replacement mode
        - Download mode
        1. PCB replacement mode
        This mode is used when replacing the main PCB or MC relay PCB.
        By executing this mode,
        - Backup data of the settings and counter values stored in the MC relay PCB are moved to the new main PCB.
        - The data such as the settings and counter values are copied to the MC relay PCB.
        a) Entering the PCB replacement mode
        Follow the same procedure as that for entering the service mode.
        (With the "Paper Source" button and "Information" button pressed down, turn on the "Power" button.)
        When the printer starts up, compare the serial number memorized in the main PCB's EEPROM with that memorized in the MC relay PCB's EEPROM. If they do
        not match, or no serial number is memorized in either EEPROM, enter the PCB replacement mode.
        While you are in the PCB replacement mode, the MESSAGE LED, roll media LED, and ONLINE LED are lit.
        b) Procedure
        Select "CPU BOARD" or "MC BOARD" using the [ ] and [ ] buttons, and then press the [OK] button to determine it.
        - CPU BOARD
        Select this after replacing the main PCB.
        The data in the MC relay PCB is copied to the main PCB.
        - MC BOARD
        Select this before replacing the main PCB.
        The data in the main PCB is copied to the MC relay PCB.
        Use this when the MC relay PCB is a new one.
        c) Exiting the PCB replacement mode
        Turning off the Power button of the printer allows you to exit the PCB replacement mode.
        For details on how to replace the PCB, see Parts Replacement Procedure > Disassembly/Reassembly > Points to Note on Disassembly and Reassembly > Boards.
        • ras63
          • Jun 2012
          • 3
          I have checked that the serial number stored in the main PCB is the same as the machine. I am not able to get to the point in the manual to replace the PCB. Is there a way to "re-sync" it? The E196-404E prevents me from even getting into the service mode. The only mode I can get to is to update the firmware, which I have already done. It will let me view information (i.e. firmware, serial no, etc)
