CLC3200 E020 04b0
  • tinnyjay
    • Oct 2009
    • 663
    CLC3200 E020 04b0
    Hello!
    As SM says,this code is related to the end of black drum life.
    When i see drums lifes,black drum is about 246(other drums are 300 -400) in Service Mode i mean.
    Somebody experienced with this problem?
    (I little help,before code apear copier was working perfectly with a high image quality)
    "Who loves the roses,must also bear thumbs"
  • vigour
    • Aug 2010
    • 1038
    Re: CLC3200 E020 04b0
    drum life is officially 100be happy if you get morethere is nothing you can do to the drum except replace it if you get a code.drums go bad at differing percentages, depending on coverage and other factors
    • Paul 75
      • Oct 2008
      • 97
      Your drums are overlife. You can normally can get 200 - 250 % at a push. Change them all together or you will get other E020 codes.
      Oh...... I can't copy at the moment then ? !!!!!!
      • tinnyjay
        • Oct 2009
        • 663
        Thank you !
