canon fax l400 error supply rec.paper
  • tariq65
    • Jun 2010
    • 84
    hello every one i'm facing problem with canon fax l400 error supply rec.paper any body tell how to solved thank you.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: canon fax l400 error supply rec.paper
    Cause: (1) Either recording paper run out or there is no recording paper cassette loaded.
    This is displayed when the recording paper sensor detects no paper.
    (2) Either recording paper run out or there is no recording paper multi-purpose
    tray loaded.
    Solution: (1) Refill the recording paper in the cassette.
    (2) Refill the recording paper in the multi-purpose tray.
    (3) Install the paper correctly.
    (4) Check if the Recording paper sensor is operating correctly using the
    methodes given in this chapter, 6.7 Faculty Tests, Test mode [6] Faculty
    test, [3] Sensor tests.
    (5) Check the Recording paper sensor on the ECNT board (PS201) and
    actuator.
    (6) Replace the ECNT board.
    (7) Replace the SCNT board.
