ERRO MACHINE IR 5020I
  • teguhkarya
    • Aug 2025
    [Misc] ERRO MACHINE IR 5020I
    I can't connect my ir 5020i to my pc
    i have lost sign in the panel, that show options
    how i can solve this problem
  • teckat
    • 16083
    Re: ERRO MACHINE IR 5020I
    1. Press the Additional Functions button.
    2. Hit Custom Common Settings or Common Settings.
    3. Select the Initial Function option.
    4. You will now see the options for the Initial Function. Select which button you would like as your default screen. Depending on the imageRUNNER model and the options installed, you will be able to set the default screen to Send, Mailbox, Fax, etc.
    5. Press OK, then Done 2x.
    6. You may need to reboot the machine to verify that the changes have taken effect.
    or------------------------------
    A loose connection between the Main Controller and the Network Interface Card (NIC) will cause the machine to loose the Scan and Send buttons on the Control Panel. Also, a bad NIC Card will cause this problem.
    Re-seat the NIC Card first and install a new NIC Card if nessesary.
