IR2870 Main controller PCB
  • Matoku
    • 173
    [Error Code] IR2870 Main controller PCB
    Hi all tech,
    Can I use the IR3570 Main controller pcb to IR2870?
    I have tried it but E733 come out. I have tried use only the pcb and reuse all the HDD, bootrom and the ram.
    I tried it due to the 2870 original main controller pcb have problem with the printer port.
    If can how to do so?
    Thanks.
    • 16083
    Re: IR2870 Main controller PCB
    Originally posted by Matoku
    Hi all tech,
    Thanks.
    yes/same pcb.
    FM2-4550-010 Main Controller Board iR2270/2870/3570/4570
    what is sub-code///// E733-????
    Ribbon cable which connects the DC Controller and Main Controller together. One of the ends could be loose.This can happen during a DC Controller or Main Controller replacement. This can also happen if one of the cable connector locks is not locked in place properly. The ribbon cable could also be damaged.The DC Controller connector side is at J301 and the Main Controller connector side is at J1029. The cable is very thin and extreme care should be used when reconnecting it to either side of the PCBs.
    • Matoku
      • 173
      Thanks For the Info Mr Teckat. I also found that its because of the boot room issue. after i use the boot room from the same main controller pcb then it works.
      Thanks.
