Gp605 E218
  • tingps
    • Aug 2007
    • 9
    Gp605 E218
    Please help! I have already changed the exposure lamp; Dc controller Pcb; inverter pcb and DC power supply unit. But the machine is still displaying the same problem.
  • logonjim
    • 136
    E218
    Check your 24v line to see have you got it . Short on this line can cause E218 clutches ,and fans, and or tight cable ties , are the main cause.
    • logonjim
      • 136
      E218
      You never said you replaced the lamp heater this is also a problem for the error and have you also done ccd adj after replcing them?
      • tingps
        • Aug 2007
        • 9
        Gp605 E218
        Thank you very much for the advice. Sorry that I have not mentioned that I have changed the lamp heater. But I have not done the ccd adjustment. I shall do that.
        The 24V is missing from the DC controller, I shall be checking from there also.
        Thanks again.
        • winsonhifi
          • 11
          E218
          hi....if the dc controller not missing 24v,then how?or missing,how to check it?
          • Matoku
            • 173
            what the final solution for this probem?
