E001-0002
  • herlin
    • Jan 2011
    • 33
    [Error Code] E001-0002
    Hi,
    We're having 2 iR-adv6055 machines which give once in a while the error code E001-0002, followed (after restart machine by customer) by E001-0010. When resetting the error, the machine can be restarted and will run for several weeks, until the next occurrence of the same errors. There does not seem to be a jam before the error, it happens during a run. Wiring and thermistors seem OK and wiring does not seem to be trapped... Any ideas?
  • bk59
    Re: E001-0002
    Look at the fixing/feeder assy connector. Are the pins ok? Is it cracked? Also even if the therms look ok . Try rpl them. Bill
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5018
      Re: E001-0002
      Folow the temperature in SM during printing.Install latest firmware.What size of paper do you using? (R).
      • vigour
        • Aug 2010
        • 1038
        Re: E001-0002
        Is there a crusty buildup on the thermistors?
        As posterd by others, there can be problems with the connectors.
        We are also having success cleaning that crud off the thermistor.
        I think it might be related to the very dry web sent with the machine
