Canon IR6575 E004-010
  • bluesky2000
    • 95
    hi all
    i have this bad error 004-010 or 004-0103
    really i need help ...
    note :-
    1- i replace power supply heater
    2- i replace DC controller
    and still the error
    helppppppppppppp.......
  • bluesky2000
    • 95
    Re: Canon IR6575 E004-010
    helpppppppp
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5017
      the same machine?
      http://www.copytechnet.com/forums/ca...highlight=e004
      • bluesky2000
        • 95
        THE ERROR IS deference
        • teckat
          • 16083
          Check below
          -Wall voltage at the wall outlet
          -AC Driver PCB Assembly
          -AC Noise Filter PCB in the Power Cord Terminal Assembly
          -UFR Heating Element
          • rado_hristov
            hi all
            note :-
            and still the error
            Hi , first of all you can clear erorr in service mode . Go in service mode by pres asterisk afrer that 2 and 8 simultaneously a asterisk again and you are in service mode . Press Copier > Function > Clear > Error clear . After that turn off and on the copier .
            • bluesky2000
              • 95
              i know that it's not work the error stil
              • gensys
                • Jan 2011
                • 323
                Replace thermoswitch by a new one
                Be sure to screw thermoswitch firmly. If the screw is loosened, there will be no gap between thermoswitch and the fixing roller, letting thermoswitch have an open-circuit.
                The Road will be Mastered by >>> the Going...
                • bluesky2000
                  • 95
                  i change all the section of roller and other things
                  it's not work.............
                  • teckat
                    • 16083
                    DID U Check below
                    • bluesky2000
                      • 95
                      Originally posted by teckat
                      DID U Check below
                      wait me for tomorrow i chick it and come back for you
                      • zelotprotos
                        • Apr 2014
                        • 36
                        DID U Check below
                        Hi..
                        I Got the same problem. Error 004-010 or 004-103 on canon ir5075.
                        But one day ,after touching some cables on the left side of the machine then the machine works without any error. I dont know why the error disappear.
                        But after putting back all the casing onto the machine I got this error untill now,
                        Could you give me the pic of AC Driver PCB Assembly, AC Noise Filter,UFR Heating Element? I dont know those parts.
                        Thank you very much.
                        • teckat
                          • 16083
                          Originally posted by zelotprotos
                          Hi..
                          ________;-)
                          See link----
                          The manuals for this machine are divided as follows. Please refer to them for detailed information. The manuals supplied with optional equipment are included in the list below. Depending on the system configuration and product purchased, some manuals may not be needed.
                          • dohha
                            • Aug 2013
                            • 12
                            hi all
                            note :-
                            and still the error
                            try the replacement of the UFR Heating Element.
                            Part number for the UFR Heating Element is FM2-3012-010.
                            good luck
                            • Canuck
                              Tech Specialist
                              • 1713
                              Replace the main thermistor assembly(2 thermistors). They translate back and forth and are NOTORIOUS for crapping out. Also check for paper pieces jammed inside drawer connector
