change IP address of an IRAC 5035
  • DANIELCANON
    • Jun 2011
    • 187
    Hello everyone, the machine has the option UFR but I can not change the IP address to connect to the network. the options are grayed.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: change IP address of an IRAC 5035
    Network setting cannot be executed unless logging in as an administrator.
    Factory default password is as follows.
    Following setting needs to be ON to perform network setting:
    • DANIELCANON
      • Jun 2011
      • 187
      Ok, thank you very much and I can make any necessary changes.
      your help is very important.
      • zoraldinho
        • Mar 2008
        • 5007
