It's part of the mod kit for the paper feed section #fc5-0567-010 pickup Assy u plate.....where does it go. Thanks kurt
Canon Ir 4570 part number
Item 17
PDF image (if I did it right). It is item 17.Attached Files -
Not sure what you are trying to do, but you do need to remove the Right Cover (rear) and Right Door to remove either Pick-up Unit 1 or 2. If you are trying to apply the vertical feed roller upgrades, both pick-up units will need to come out.
I strongly suggest you convince your boss to spring for a service manual and parts manual.Comment
