Canon irc2620
  • mramlawi
    • Jul 2011
    • 838
    Canon irc2620
    Dear all
    I have canon irc2620 when the client order to print the machine turne off then on automatically no error codes on history,i debout on power supply or the mfc ,my question is this problem always happen on this series we change power supply some times it works some times its not ,any one know if we can repair the power supply or the mfc, i mean whats the thing that occuar the problem
    Distinguished road makes you jewel in rough
  • teckat
    • 16083
    Re: Canon irc2620
    MAKE SURE U DON'T HAVE A OUTLET ISSUE/
    printer needs AC not to rise or drop -/+ 10%/15% during operations / power surge or drop will shut down printer
    only way to check is with a line monitor connected/w a print out
    is the main printer switch tripping off ??
    or are u just loosing power to printer (control panel goes blank>green power light stays on) ???
    • mramlawi
      • Jul 2011
      • 838
      Re: Canon irc2620
      hello ,
      yea just loosing power to printer (control panel goes blank>green power light stays on) yea that;'s what exactly happen ,and this problem always occur on this machines .
      • teckat
        • 16083
        Re: Canon irc2620
        Originally posted by mramlawi
        hello ,
        Check the connection between the Sub-Main Controller (J1303) and the Main Controller (J1209) to see if they are seated correctly. When installing the Sub-Main Controller press the connectors together, then install the standoff screws-
        have u done outlet checks ?????????????
        **Do not forget to check your wall voltage> especially between
        Neutral and Ground
        >Ensure that the voltage between the neutral and ground poles is 1/2 a volt or less
        If the voltage is higher than 1/2 a volt, an electrician needs to look at and correct the outlet
        • mramlawi
          • Jul 2011
          • 838
          Re: Canon irc2620
          Neutral and Ground
          sure i checked the outlet from the beginning and its okay, i changed the power supply board and the machine is under test now .
