i have question for ir 6570
  • bluesky2000
    • 95
    hi all ...
    i wont the setting for feeder :
    i put a paper A4 landscape in feeder and print it with tray 1 in my device ?
  • teckat
    • 16083
    Re: i have question for ir 6570
    Originally posted by bluesky2000
    hi all ...
    User Mode
    Common Settings
    enable/disable cassette auto
    copier
    /printer/box/other (manual feed: ON/*OFF + individual
    cassette: *ON/OFF)
    (manual feed not possible for printer)
    set delivery tray**
    (w/ finisher)
    - Finisher-T1/Saddle Finisher-T2
    tray A: copier, box, printer, reception/fax*, other*
    tray B: copier*, box*, printer*, reception/fax, other
    tray C: copier*, box*, printer*, reception/fax, other
    tray basic position: tray B*/tray C/not selected
    detail setup:
    tray A: reception*/fax*
    tray B: reception/fax
    tray c: reception/fax
    set printing priority copier: *1/2/3
    printer: 1/*2/3
    box: 1/2/*3
    reception/fax: 1/2/*3
    other: 1/2/*3
    ADF- adjustments in service mode
    ----Tray width adjustment
    COPIER > FEEDER > FUNCTION
    FEEDER>FUNCTION>TRY-A4
    FEEDER>FUNCTION>TRY-A5R
    FEEDER>FUNCTION>TRY-LTR
    FEEDER>FUNCTION>TRY-LTRR
    ADF sensor sensitivity adjustment
    FEEDER>FUNCTION>SENS-INT
    COPIER > OPTION > BODY
    MODEL-SZ Use it to switchover the default magnification ratios and ADF original size detection.
    0: AB (6R5E)
    1: inch (5R4E)
    2: A (3R3E)
    3: AB/inch (6R5E)
    • bluesky2000
      • 95
      I want to put paper in the lengthwise and use feeder to print it using the first cassette
      • teckat
        • 16083
        what size paper is in tray #3 ??
        if A4> just adjust direction to A4R >> SEE BELOW
        u probably mean cassette #3
        first
        cassette >the one below the decks
        see below
        1) Press the Additional Functions key.
        2) Select the Common Settings option.
        3) Scroll until you see the option for Drawer Eligibility for APS/ADS.
        4) Depending on which model imageRUNNER being set, some of the following options are available for selection: Copy, Printer, Mailbox, Fax, and Other.
        5) Once the selection of Copy, Printer, Mailbox, Fax, or Other is made, go to the cassette notation where the paper is located and select ON .
        6) Press OK, then Press Done.
        in LEVEL1
        In service mode level 1 COPIER>OPTION>BODY>MODEL-SZ is set at 3
        in LEVEL 2
        Also make sure the Copier> Option > Body>model SZ2 is set correctly and Copier>Option>User >Size Det. is set.
        set both to 1
        Cassette 3
        COPIER > FUNCTION > CST > C3-STMTR/A4R
        Use it to register the paper width basic value of the cassette 3.
        1) Put STMTR/A4R paper in the cassette3, and adjust the slide guide plate to the width.
        2) Select C3-STMTR/A4R to highlight, and press the OK key so that the machine executes auto
        adjustment and register the value.
        Cassette 4
        COPIER > FUNCTION > CST > C4-STMTR/A4R
        This operation is similar to cassette 3.
        • bluesky2000
          • 95
          ok sir
          thank you so much for help
          look, i put in feeder paper A4/R
          and print it by use the first cassette ((( the first cassette is A4 )))
          i don't want to print with third cassette ((( third cassette A4/R )))
          i want the first cassette because it fast ....
          • iRC
            Summer trainee!
            • 96
            ok sir
            The iR6570's cassettes 1 and 2 cannot be changed to A4R. They are only meant for A4 or LTR.
            And A4R is always slower than normal A4.
            • teckat
              • 16083
              imageRUNNER 5570/6570 -speed in red for 6570
              Copy Speed Up to 55cpm, 65cpm (LTR), 31cpm, 31cpm (11” x 17”), 39cpm, 39cpm (LGL),
              43cpm, 50cpm (LTRR), 35cpm, 35cpm (STMTR)
              Multi-page Copy Speed
              click on pic to expand
              • bluesky2000
                • 95
                ok it's work
                but there are a one problem
                when i put a paper A4R in feeder and print it the machine read it is A3 why !
                • teckat
                  • 16083
                  ok it's work
                  what does the #3 tray READ OUT say on control panel when it's loaded with paper in A4R direction ??
                  if it does not read A4R>>do a
                  Copier>Function>CST adjustment--see below
                  Cassette 3
                  Cassette 4
                  if control panel sees A4R paper in tray #3
                  do this below ADF adjustment below
                  • bluesky2000
                    • 95
                    yes the control panel sees A4R paper in tray #3
                    i do that ok
                    wait me
                    but i think there are problem with Length and width
                    Well I try and will give you the results
                    • bluesky2000
                      • 95
                      i do it
                      but it still read the paper A4R in feeder as A3 when i print it
                      • teckat
                        • 16083
                        i do it
                        when it says A3 on control panel LCD > before u hit print key> lift up DF and see location of paper on glass
                        where is it ????
                        DF
                        Identifying the Size of the Original-
                        Normal Printing
                        The machine identifies the size of an original with reference to combinations of the size (width, length) detected on the original tray and the size (length) detected while the original is being moved.
                        a. Detecting the Size of the Original in Feed Direction
                        The machine detects the size of an original in feed direction with reference to the state of the post-separation sensor (PI7) after the read sensor (PI8) has gone off and the state of the LGL sensor (PI4)on the tray (LGL/STMT).
                        The machine measures the length of the time from when the read sensor goes on to when it goes off to find out the length of the original; it then uses the result of the measurement and the result of detection made on the original tray to identify the size of the original.
                        When an original is placed on the original tray, the light-blocking plate operates in keeping with the detecting lever of the LGL sensor to block the light of the photo interrupter. The machine identifies whether or not the original is LGL with reference to the LGL sensor signal (LG_S) and the width of the original. The machine communicates the original size information to the host machine as soon as the Start key is pressed.
                        Detecting the Size of the Original in Width Direction.
                        The width of an original is detected using the original width detecting volume (VR1) found inside the original tray.
                        The volume operates in conjunction with the slide guide, its resistance changing (analog) as the slide is moved. The ADF driver PCB reads these changes in resistance as the original size signal (WIDTH), and recognizes them as specific widths.
                        To make sure that the original width volume (VR1) correctly detects A4R/LTRR and A5R/STMT widths, a special AB/inch sensor (PI4) is used inside the original tray; the sensor goes '1' (AB/inch identification signal) when the width of the original is 197 mm or more and less than 214 mm.
                        The track of the slide guide is given a groove so that the slide may stop at specific default sizes. Some sizes, however, are extremely close to each other, possibly causing the slide to stop at the wrong point. To make sure that the slide stops at the correct stops, the slide is provided with a positioning roll [1], which restricts the stops as follows:
                        Marking on slide guide positioning roll--A4R----------Slide guide stop position
                        A4R--------------------------------------------------Side with 1 groove
                        A4R/LTRR--------------------------------------------Slide with 2 grooves
                        Marking on slide guide positioning roll--INCH----------Slide guide stop position
                        LTRR--------------------------------------------------Side with 1 groove
                        • bluesky2000
                          • 95
                          OK
                          i have 2 machine ir 6570 ok
                          look , i change the all section ( Feeder ) one by one . and still the screen read A3 when i put A4R in feeder
                          now i think the problem with machine not in the feeder . i mean in service mode .....
                          Tomorrow will take a picture of the problem and will see it
                          thanks man for your help
                          thanks so much
