C3220 copy quality
  • repeatcopiers
    • Sep 2008
    • 591
    C3220 copy quality
    We have a C3220 in the field that occassionally produces the attached copy. Any ideas?
  • teckat
    • 16083
    Re: C3220 copy quality
    Glass Copy or Network Print/ or both -------------
    if from glass> i hope u are not trying to copy money or document with a hologram
    u may have activated the counterfeit protection
    • repeatcopiers
      • Sep 2008
      • 591
      This happens when printing from the computer. And it is on standard documents, no money.
      • teckat
        • 16083
        check all the connectors on MAIN CONTROLLER pcb.
        there is a IC1015 (CHIP) that overheats and causes similar issues
        IC1015
        JPEG compression
        JPEG decompression
        Resolution conversion
        Rotation
        Binary processing
        MMR compression
        • repeatcopiers
          • Sep 2008
          • 591
          In addition to the wierd copies, now this machine is also shutting down (screen blanking out but power light staying on) customer has to turn off/on, then remove the jam.
          We have replaced the Memory, Main Controller and Power distribution board......any other ideas?
          • teckat
            • 16083
            1- defective Boot ROM
            2- defective Control Panel
            3- Fuse Pcb (known problem in this model) fuses must read exact voltage (u can't test for continuity because low voltage on fuse will still read good)
            4- check the Main Controller Fan
            5- defective Sub Main Controller ( this pcb causes many issues when it starts to go bad)
            6- Ensure that the voltage between the neutral and ground poles is 1/2 a volt or less. If the voltage is higher than 1/2 a volt, an electrician needs to look at and correct the outlet.
            7- inspect the Main Controller PCB LED101, if the LED is OFF, then replace the SRAM PCB (FG3-3669-000) which is mounted on the Sub Main Controller PCB.
