hard drive storage ir c5185
  • pontiac
    • 420
    Is there any way of retrieving or finding out what docs or info is stored on the hard drive and also can i clear the hard drive without clearing any operation software. Copier has H1 fiery. Thanks
  • Jonhs
    Re: hard drive storage ir c5185
    The Fiery hard drive info can be looked at using Command workstation a program that came with the RIP.CD's. By default it stores the last ten prints sent to it. This can be increased to 99. The copier hard drive can not be read the data written to it is scattered across the drive and its location is stored on the ram and erased anytime the machine is turned off. Unless they stoed it to the mailbox. You can do partial clears to the hard drive using service mode Function>SystemCHK-TYPE Used to specify partition number when performing HD-CHECK or HD-CLEAR.
    Operation method
    1) Select this item.
    2) Use the numeric keypad to select the desired partition number.
    0: Check and restore all bad sectors on hard disk
    1: Image storage area
    2: General-purpose file storage area
    3: PDL file storage area
    4: Firmware storage area
    - General-purpose files include user-set data, log data, PDL spool data, and management information for image data.
    3) Press the OK key.
    1
    HD-CHECK Use it to check the entire HD and perform recovery.
    Operation method
    set '0' to the following: COPIER>FUNCTION>SYSTEM>CHK-TYPE
    2) Press the OK key.
    1
    HD-CLEAR Initializes partition specified by CHK-TYPE item.
    - The following must be kept in mind and the user must be properly informed of the fact when using CHECK-TYPE:
    0: entire HDD -> no operation occurs (to initialize, use the SST)
    1: image storage area -> removes image data
    2: general-purpose file area (user settings data, various log data, PDL spool data, image data control information) ->
    initializes files
    3: PDL-related file storage area -> removes font data, requiring re-installation
    4: firmware, address book, filter storage area -> no operation occurs (to initialize, use the SST)
    Operation method
    If you perform <HD-CLEAR> after selecting 1 (image storage area) or 3 (PDL file storage area) for the <CHK-TYPE>
    item, the initialization process is performed after the power is turned OFF/ON.
    The initialization process takes about 5 minutes. A progress bar slowly advances to indicate the progress during this time.
    Never turn the power OFF during this time.
    1
    DEBUG-1
    • vigour
      • Aug 2010
      • 1038
