Canon usb to parallel cable..?
  • AdamS87
    Does anyone know where one of these could be obtained. I have a client that has a Cannon IR3300 that needs the HDD replaced and the firmware installed. I have SST but I have read in multiple places that a "Canon" USB to Parallel is the only way to interface with this machine to install firmware and a crossover cable will not work.
    Thanks in advance,
    Adam
  • canonbundy
    • Jun 2012
    • 607
    Re: Canon usb to parallel cable..?
    Thanks in advance,
    Adam
    Not only do you need a new HDD, but maybe 1 that has the Canon specific P/N: also an older laptop with a Parallel Port and an earlier version of SST, they are not Tech friendly.
    • its_just_a_copier
      • May 2011
      • 132
      Some more info for you :
      USB-Parallel cable (FY9-4368-000) supports Windows Vista / Win 7 with Service Support Tool (SST) v4.22 or above.
      USB-Parallel cable (FY9-4154-000) does not support Windows Vista / Win 7 regardless of the version of SST.
