Canon IR 2230
  • kmtech
    • Sep 2008
    • 125
    [Jamming] Canon IR 2230
    This machine is jamming when starting up the right side door, I replaced the primary feed rollers and reverse and ran fine for about 4 Days. they called back and said its still jamming in the same place, went back and cleaned the feed rollers on the side door and it worked fine again but after 4/5 days it started jamming again cleaned rollers again I'm sure they will call back. looking for some ideas, thanks.
    Bill
  • doktor
    • 214
    Re: Canon IR 2230
    Jam code please.
    • teckat
      • 16083
      Re: Canon IR 2230
      Bill
      Check that micro-switch MSW2 is actuating properly--MSW2 is actuated by linkage from the right side door.
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5013
        Re: Canon IR 2230
        Did you replace all this?
        FM2-0132-000:Right Lower Inner Door Assembly
        FM3-1296-000:Right Lower Door Assembly
        FC5-0567-010:PICK-UP ASSY MOUNT,U PLATE
        FC5-0641-010:SENSOR COVER
        FB6-4852-000:VERTICAL PATH ROLLER
        • kmtech
          • Sep 2008
          • 125
          Re: Canon IR 2230
          No I did not replace all of this, it seems a bit much but if it will fix it i guess it must be done. r u a sharp doer I do mostly KM an Ricoh, just doing a customer a favor on this machine. you know how that goes you always over load your a--.
          • skibum
            Independent Service Tech
            • 231
            Re: Canon IR 2230
            There are oneway gears that drive the vertical pass rollers in the right paper feed door area that can slip on the shaft (2 rollers identically set up with the one way gear). If so first scotch brite the shaft to buy time while gears are on order, you should change the roller that gear rides on as well. Does it happen on both draw feeds, first determine if it is both draws. If paper is not even at the vertical pass rollers and only one tray jams, then look at the torque limiter clutch to the tray that jammed. The torque limiter is near the seperation roller usually the same shaft that sep roller rides. Good Luck
            • kmtech
              • Sep 2008
              • 125
              Re: Canon IR 2230
              Hey Guy, thanks i will try these tips and let you and all know the out come....
              • zoraldinho
                • Mar 2008
                • 5013
                Re: Canon IR 2230
                this is just guessing.To be shore,we need a jam code.
                • skibum
                  • 231
                  Re: Canon IR 2230
                  Jam code is a good start. Careful, they can lead you away from the source if you don't understand how things function. Then it becomes replace everything the book says. The manufacturer wins on this logic and they wrote the manual that says change this with this effect. Don't get me wrong, the jam code will help more often then not to atleast get you in the area of the problem. Just don't troubleshoot with parts, that is not cost effective.
                  Things can mimic other causes, keep an open mind. How is the paper they are using. Recently I had a customer change brands of paper and they called because they suspected the paper. They changed back to what they were using. The A/C at this time of yr in the east is not on full time. Between seasons I often have more jam problems.
