C1 problem after clean ITB
  • Alessandro72
    • Jul 2009
    • 31
    Hi all,
    my canon c1 reported the error E070, so I removed the ITB, clean the sensors and put back in its place.
    After the printing result is what I enclose in the picture. What could this happen?
    Also now often report the error E020.
    Thank you for your time.
    https://t.me/pump_upp
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Re: C1 problem after clean ITB
    E20 is result for pure image on ITB.(check connectors) Sub code??
    E70... sub code? (old ITB,dirty ITB inside)
    • Alessandro72
      • Jul 2009
      • 31
      E20 0189
      The sub of 070 not remember...
      • Alessandro72
        • Jul 2009
        • 31
        It is possible that after the reassembly the ITB is not perfectly aligned with the drum?
        I say this because in the first centimeters of print the toner (left of the sheet) seems to be fixed properly.
        I do not know what to do!
        • zoraldinho
          • Mar 2008
          • 5018
          Jes,it's possible.Check primary transfer pressure lever.
          • Alessandro72
            • Jul 2009
            • 31
            the lever is ok....!!
            • Alessandro72
              • Jul 2009
              • 31
              I'm beginning to understand something ... at least I think!
              By lifting the lever the belt only rises left and right does not rise.
              From the photos that you can attach to understand what might have happened?
              It is perhaps a few pieces detached during disassembly?
              thanks so much for your patience
              • Van Steal
                • 177
                your missing the arm that racks up the belt at the rear. Its the same as the one on the front.
                • zoraldinho
                  • Mar 2008
                  • 5018
                  You are not trained tech on this model,aren't you
                  Do you work with service manual on C1?
                  • Alessandro72
                    • Jul 2009
                    • 31
                    Thank you Steal and Zora.
                    Can you tell me if it's a piece that I can order a canon or I'll think of something?
                    • zoraldinho
                      • Mar 2008
                      • 5018
                      Check if you have 2 release cam on the both sides.
                      FC5-1671-000 2x (CAM, RELEASE)
                      • HELIO240
                        • Jan 2011
                        • 137
                        Originally posted by Alessandro72
                        Hi all,
                        • Alessandro72
                          • Jul 2009
                          • 31
                          Zora thanks for the code, you have been very kind.
                          Hello elios, the rear sensor actually measures 240, tried to do PT-LPADJ but remains at 240.
                          Tomorrow I'll try to do clean the sensor, and hopefully good!
                          • HELIO240
                            • Jan 2011
                            • 137
                            Hi alessandro, in this case you must change the connector cable of sensor patch. FM2-1615-000 item 46 figure 610 manual parts. There some wire broke.Please return.
                            • Alessandro72
                              • Jul 2009
                              • 31
                              I cleaned the three sensors, now the first one is at 205, the second at 0 and the third at 240.
                              Helios I can not find the code to replace of the cable, where is it?The key number for the figure 610 stops at 44
                              Thanks to all
