Canon image prograf ipf 755 printhead error
+ More Options
Posts
  • Boomer7
    • Jul 2011
    • 17
    I have an ipf 755 in the field and I do not have a service manual or access to a service manual. The error is E161-403E which is a overheat error and the process is to change the printhead. I have a new print head but I am unable to access service mode. Can anyone tell the process of entering service mode and installing a new print head after this particular error. I sure would appreciate any help customer is down needs to print proposals for bids. Please indicate exact buttons to press for service mode thanks
  • Obetech
    • May 2011
    • 14
    Re: Canon image prograf ipf 755 printhead error
    Hi Boomer
    on the IPF machine you don't need to enter service mode to replace printhead.
    However to enter service mode:
    1) turn off the printer power
    2) turn on the power while pressing [LOAD]key an [NAVIGATE]key
    keep pressing the above keys until "INITIALIZING" is displayed
    3) "S" appears at the top right of the display
    4) press the left or right arrow key to choose the [SET/ADJ MENU] and press [OK] key
    "SERVICE Mode" appears in the menu list and the message led flashes.
    to exit turn power off
    hope this helps
    • yourownfree
      • Dec 2007
      • 474
      Just a note for those who get this error. In order to clear this code you need to go into service mode, let it do its thing, booting etc. even if it comes up with another error later of a different kind, which at that point shut it down and reboot normal. Just going into service mode will clear the error. If that dont work after replacing the head, then replace the carriage relay pcb. I just went through this myself.
      • teckat
        • 16083
        Originally posted by quinguyen
        Error nozzle overheating by automatically cleaning several times and repeated heating phenomena should lead to definitive circuits and nozzles (In this case, no editing, just started in a new place all of you)
        For more information on Canon large format machine you can refer to the website: KH or a printer? L? N PRICE R? T? NG TOGETHER M? C SD 01 N? M. You can call anytime 0983000024 for direct instruction
