need to do a factory reset on a irc4080
  • Jerrygbs
    • Dec 2008
    • 193
    [Misc] need to do a factory reset on a irc4080
    My wholesaler sent me a irc4080 which came from a kinkos . The machine runs great BUT when it comes ready it gives you 3 chooses b&w , color, or color/b&w. after picking one of these choices you get the normal screen, also it has usend but the tab does not so up on the screen. I've tried MMI clear but this doesn't reset the machine to boot up to the normal screen. Any help will be appreciated.
    Re: need to do a factory reset on a irc4080
    service mode level 2 > copier > option > body
    UI-SEND Used to select whether to display operation panel send screen
    0: Don't display
    1: Display [Factory default/After RAM clear]
    • Jerrygbs
      • Dec 2008
      • 193
      Originally posted by skynet
      Initialize common / copy settings ?
      0: Don't display
      that reset the usend to show a tab but the 3 choices still show up . Ive found a reset under system settings that is taking 26 minutes we'll see if that fixes the boot up screen hopefully.
      • arielcanon
        • Mar 2012
        • 106
        resetting all system data/setting will not change the values on service mode...,
        Learning never ends..
        Never give up, where there is a wheel there is a way..
        • Jerrygbs
          • Dec 2008
          • 193
          after boot up the screen says pick copy type then there are 3 choices after you pick one it goes to the normal screen but after pushing reset key it goes back to the three choices .
          • Ikon Princess
            • 126
            If this copier has a fiery attached then it has its own Kinko's fiery system software. If you can get regular system software it may make the screen look "normal".
            • teckat
              • 16083
              check this setting>under>
              Additional Functions>Common Settings>Printer Settings
              Color mode *Auto, full color, mono color/
              make sure it is set for AUTO-
              if set for AUTO - and same issue pops up-u can try>under-
              Initialize common settings *Yes, no-
              select YES / all control panel settings will revert back to standard settings
              u can also set both on
              Additional Functions>System Settings>Color Mode for Copy
              - Use Auto-Color Select>ON
              - Full-Color>ON
              • Jerrygbs
                • Dec 2008
                • 193
                I have a H1 off of a irc5080 will that work in place of the kinkos fiery?
                • Ikon Princess
                  • 126
                  Yes they use the same fiery.
                  • Jerrygbs
                    • Dec 2008
                    • 193
                    I have it attached and its working fine. But no matter what i try that stupid screen that tells you to select type of copy wont go away. It does that with or without the fiery. Its not that big of a deal i can talk my way around it with the customer but its annoying .
                    Thanks for all your help
                    Jerry Jacks
                    GBS
                    • Ikon Princess
                      • 126
                      Maybe it was system software on the copier itself. It was over 3 years ago that I set up and maintained those Kinko's machines, but I do remember installing software that made the screens look like that. Hope that helps.
                      • Jerrygbs
                        • Dec 2008
                        • 193
                        thanks if the customer gives me a hard time maybe ill reload firmware.
