Help me! IRA-6055
  • chungnt2511
    • 5
    Help me! IRA-6055
    in have a copier IRa-6055 display Error E0005-0001
    Please help me!
  • seniortech
    • Dec 2007
    • 180
    Re: Help me! IRA-6055
    E005 -0001 -05 Title Error in Fixing Cleaning Web Drive Solenoid connection
    1. Check the Connector of the Fixing Cleaning Web Drive
    Solenoid.
    2. Check the output of the DC Power Supply PCB (24V)
    (PCB31). Using a tester, check whether 24V is output from 3PIN
    through 6PIN of J513 on the Relay PCB. In case of error,
    replace the DC Power Supply PCB (24V) (PCB31) (on the
    right).
    3. Replace the Fixing Cleaning Web Drive Solenoid (SL9
    • Rachid.Akli
      • Oct 2011
      • 595
      Replace the cleaning web: FY1-1157-000000. Be sure to reset the reading in service mode: COPIER>COUNTER>MISC>FIX-WEB,
      COPIER>COUNTER>DRBL-1>FX-WEB.
      Rachid.
      "Find a job you love and you’ll never have to work a day in your life." Nagy's father
      • chungnt2511
        • 5
        Solenoid.
        right).
        Thanks for help ! I will try
