error code E602-003
  • johnsonisaacnigltd
    • Mar 2011
    • 32
    [Error Code] error code E602-003
    Please, I have Canon IR 3320 which the hard drive is bad. I replaced with a new hard drive which already programmed, but when I put on the machine is not working. Can anybody help with how to install the hard drive.
    thanks
  • rado_hristov
    Re: error code E602-003
    thanks
    The main reason is that version of system softwawe , boot ROM , Fax and RUI did not mach . You have to install one version for all those elements of software via SST ( Service support tool )
    • rado_hristov
      Originally posted by Canon.Tech
      After you have replaced the hard drive you need to install the correct firmware using the Canon SST (service support tool)
      голям професор !!!
      • teckat
        • 16092
        Originally posted by rado_hristov
        голям професор !!!
