We have an issue with IR 2016i which operates on 120v/60Hz. The problem is when legal paper is used the print comes out then display shows "Change paper". Customer has to reset the M/c for every copy/print. Also duplex cannot be taken since this message is displayed after first side is taken. We do not face such problem when using the same paper with other IR series 2870/3530/3025 etc. But problem is there in IR 2016, 2018,2020,2022 only so far we checked
This is due the standard legal paper size available here in India is 215mm x 345mm but the legal size in machine driver setting is 215.9 x 355.6.
We have now set the legal paper to be used as "Custom Size"(215mmx345mm) and using the bypass tray. Duplexing is not possible but we dont get the "Change paper" message after every copy/print.
What I want to know is if there is any update/solution available for this problem or any way the paper size in the driver can be altered so the same paper may be used in the cassette and duplexing enabled ?? Please give your inputs
Thanks in advance
DB
Thanks in advance
DB
