I can't understand how machine checks is drum inside or no? I looked for sensor in service manual, but i do not see special sensor for it. If somebody can explane what is symbol of sensor in SM, or were it placed? Thanks!
iR2520. display message: insert drum.
Re: iR2520. display message: insert drum.
The message "Insert Drum" is on the display, however, the drum is correctly inserted in the machine. The drum unit had been replaced and the high voltage contacts were clean and not deformed in any way. An "All Clear" was performed as well to no avail.
Workaround :
In this case, replacing the H.V.T. resolved the issue.
FM4-2871-000 iR2535(i)/2545(i)
FM4-2872-000 iR2525/2530 -
This error appear if drum bias not contact correctly to contact point of drum (you can see contact point of drum: open drum cartridge, see at the back of drum, there is a leaf spring inside the hole, pull out with a little force). ussually this error come up when replace individual drum not unit. when drum turn, ussually drum will shift to the front leading to poor contact of drum bias. I myself use a small washer with approx 0.8mm to keep drum bias.Learning never ends..
Never give up, where there is a wheel there is a way..
thor
Try updating DC CON firmware to latest version. I have solved 10 so far by updating firmware. It changes the threshold for the bias so it will not error out.Comment
Thanks to all who tried to help! Really the main PWB was broken. Firmware downloading was without sucsessComment
Workaround :
I have solved this issue by replacing HVT
FM4-2872-000 iR2525
Thnks alotComment
megaivan01
Hello. I have IR2202 with the same problem: Insert Drum Cartrige (Drum cartridge is not inserted). I check all connectors, disassembly the half of copier but find nothing. Can you help me with this problem?Comment
You can fill in the form on my webpage and I will contact you for more assistance https://3dboland.wixsite.com/3dboland/contact
Thank youLast edited by ALTparts; 11-29-2017, 08:41 PM.Comment
