IR1023 Error code E197
  • LennoxD
    • Sep 2011
    • 82
    keep getting paper jam indication but no paper is jam. after resetting error code E197 is displayed. Can anyone advise on which specific board needs to be replaced to correct problem.
  • montana
    • Aug 2008
    • 392
    Re: IR1023 Error code E197
    E197 0000 Printer engine communication error
    Erroneous communication between the DC controller PCB and
    image processor PCB was detected.
    - Check the connectors of the DC controller PCB and image
    processor PCB.
    - Replace the DC controller PCB for normal connection.
    - Replace the image processor PCB.............
    • MELLO
      processor PCB.
      • teckat
        • 16083
        make sure that your wall outlet has proper ground>>>VOLTAGE
        HOT to NEUTRAL
        HOT to GD
        GD to NEUTRAL
        GROUND= +/-0V>0.5v
        • LennoxD
          • Sep 2011
          • 82
          Replaced both DC Controller and Image Processor and still getting error code E197. Any other suggestion?
          • teckat
            • 16083
            did u check the outlet for stable voltage ???/
            e197 is known issue on this model with unstable voltage-
            also check Flat ribbon cable between the DC and the IP pcb
            & Fix Unit
            • LennoxD
              • Sep 2011
              • 82
              Update on Error code E197. The problem was the drum unit. For some reason after replacing the drum unit the error disappeared. Something new for your database.
