Canon IRC1021i error E000202
  • copiertech
    • Oct 2010
    • 55
    [Error Code] Canon IRC1021i error E000202
    Hi,
    Guys I am getting the following error in Canon IRC 1021i ( error E000202)
    Any ideas????
    Waleed
    Waleed
    Copiertech
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Re: Canon IRC1021i error E000202
    The CCD unit moves backward, but does not move to the home position.
    • copiertech
      • Oct 2010
      • 55
      No the CCD is stay still in the same place no moving.
      Waleed
      Copiertech
      • copiertech
        • Oct 2010
        • 55
        HI,
        YES THE MOTOR MUST BE REPLACED TO WORK NOMALL.
        THANK zoraldinho.
        WALEED
        Waleed
        Copiertech
        • zoraldinho
          • Mar 2008
          • 5018
          Originally posted by copiertech
          HI,
          THANK zoraldinho.
          WALEED
          • raphlac
            As the same problem is on my 8450 ( near similar model ): I confirm motor must be changed. This motor model is a mitsumi m35sp-13nk, canon ref FK2-5287.
            I don't know if irc 1021i have the same motor in his scanner, but it may be interesting, cause I 'm afraid to not obtain any shop to sell this motor.
            Does anyone know any shop where can i obtain this motor or similar ?
            Best regards.
            Raphael.
            • copiertech
              • Oct 2010
              • 55
              Hi,
              you can find the full platen not only the motor since canon dose not sell the motor only.
              Good luck.
              Waleed
              Copiertech
              • raphlac
                Hi,
                Good luck.
                Thanks for this info. And do you know where can i find this platen / and which reference is used for this part ?
                I'm happy to read you.
                Raph.
                • copiertech
                  • Oct 2010
                  • 55
                  Hi, you got to contact the canon service center to get the platen cover, if they don't have it so you can buy it online or send the machine model. Send me your full details on the pm section. Waleed
                  Waleed
                  Copiertech
