canon ir5050 id y password perdidos
  • ponchoaquino
    [Error Code] canon ir5050 id y password perdidos
    me pide el id y password de la canon ir5050 y no se como desbloquear para que pueda sacar copias, como puedo hacer para empezar a sacar copias
  • teckat
    • 16083
    If Dept. ID Management is turned on, before you can delete a Dept. ID, you must know one ID and password to get to Additional Functions.
    To delete one or more Dept. IDs, follow the steps below:
    1. Press Additional Functions from the Control Panel.
    2. Select System Settings.
    3. Select Dept. ID Management.
    4. Select Store Dept ID/password.
    5. Select the Dept. ID you want to delete and select Erase.
    6. Select Yes to erase the Dept. ID.
    7. Click Done 3x to return to the main screen.
    NOTE: If you do not know one of the Dept. ID and password, you must know the System Manager ID or you can set one up. If you do not know the System Manager password either, you then can delete the System Mgr password in service mode.
    How to Clear the System Settings or System Manager's Password
    For the imageRUNNER-iR Series, imagePRESS and other Color-Enabled imageRUNNER models:
    1) Go into Service Mode by hitting [Additional Functions-2 and 8-Additional Functions]
    2) Select [COPIER]
    3) Select [FUNCTION] (One of the buttons across the top of the LCD)
    4) Select [CLEAR]
    5) Scroll to screen two of the LCD using the Right arrow key.
    6) Select [PWD-CLR]
    7) Hit [OK]
    8) Hit the RESET button twice in order to return to the Main LCD Screen.
    This will turn off the Department ID Management feature on the machine (without deleting the configured Department IDs and Passwords) and will clear out (delete) the System Manager ID and Password.
    It might be necessary to Power the unit Off and then Back ON
