E0014-0003 in IMAGEPRESS C1
  • Joseph2011
    • Aug 2011
    • 88
    [Error Code] E0014-0003 in IMAGEPRESS C1
    buenos dias:
    podrian ayudarme en una ip C1 me sale no muy seguido el codigo E0014-0003 ra revise la unidad de fijacion pero el codigo es en forma aleatoria , puede trabajar bien un par de dias y luego sale de nuevo el codigo
    gracias por su ayuda
    good morning:
    could help in a C1 ip not often I get the code e0014-0003 ra review the fixing unit but the code is random, can work well a couple of days and then rises again the code
    Thanks for your help
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Re: E0014-0003 in IMAGEPRESS C1
    Buenos dias:
    There is not a sufficient space [C] between the flange [A] of the one-way gear (FU6-0646) in the rear side of
    the fixing assembly and the push-on area of the rear fixing gear (FU6-0651); the torque may be increased,
    causing E014-0003.
    Read PDF......ipc1-058.pdf
    • Joseph2011
      • Aug 2011
      • 88
      Originally posted by zoraldinho
      Buenos dias:
      causing E014-0003.
      Read PDF......[ATTACH]16585[/ATTACH]
      ok I check it and let you
      thank you very much
