IR 7105 2-2 issue
  • Alex ahir
    • May 2012
    • 125
    [Misc] IR 7105 2-2 issue
    Hey friends,
    i have one IR7105 it is giving some weird problem, when i copy/printing one side its works fine perfectly but when i do 2-2 side one side is ok and another side will light printing very light compare to one side. i tried everything but no luck please give some suggetion. one more thing 11 x17 2-2 side print/copy absolutaly perfect only letter size has issue.
  • kingpd@businessprints.net
    • 921
    Re: IR 7105 2-2 issue
    Try new paper.
    • mramlawi
      • Jul 2011
      • 838
      if u attach a sample will be better also specify what u actually change
      Distinguished road makes you jewel in rough
      • Alex ahir
        • May 2012
        • 125
        here is the attachment of those copies. i checked its not a paper
        • zoraldinho
          teacher-guide-expert-guru
          • Mar 2008
          • 5007
          What "everything" did you try exactly?
          • Paul 75
            • Oct 2008
            • 97
            Looks like your losing transfer on the 2nd side. I would put a new trans/sep assy in firstly. You can go into option - body - and change the a setting that will adjust charge levels TR-SP-C1 to C5 from 0 to 1 . Or try adjusting the fuzzy control from 0 to 3 . Try one then the other but i wouldn't set them both on together. If these dont work i would do a dc con clear but do a p print first. If still no good i would replace DC and AC hvt's.
            Oh...... I can't copy at the moment then ? !!!!!!
            • Alex ahir
              • May 2012
              • 125
              i changed transfer assembly, all chargers update copier to higher version., developer unit
              • Herrmann
                • Jan 2006
                • 792
                Seen this before, try this one:
                raise the transfer wire approx 1mm (one turn of the screws underneath) and lower the two sep wires 1mm. Worked for me.
                Good Luck
                If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
                • spectraindo
                  • May 2008
                  • 313
                  Try this : COPIER > OPTION > BODY > TRNSG-SW = 2.
                  I have done it before when I got transfer problems.
                  • mramlawi
                    • Jul 2011
                    • 838
                    Hello for all
                    Follow my friends reply i agree them it looks like transfer problem
                    • Alex ahir
                      • May 2012
                      • 125
                      Thanks guys for all yur help,
                      I tried paul's suggetions and it worked for
