ADV 7055 giving White copy
  • Alex ahir
    • May 2012
    • 125
    [Misc] ADV 7055 giving White copy
    ADV 7055 is not printing any color black is fine but missing all colors, i change itb, drums but same when do test 10 no. it prints only black lines other colors are missing. any idea
  • teckat
    • 16083
    Re: ADV 7055 giving White copy
    did u check C-M-Y drums to see if any PG10 image is on them before transfer
    Make sure Primary Transfer Rollers are being lifted properly
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5012
      As new technologies, the machine performs the primary transfer attachment and detachment
      method, in which YMC primary transfer rollers are disengaged at Bk single-color mode to
      prolong the life of the image formation unit.
      <Details of the Control>
      1) The cam rotates, driven by the primary transfer roller disengagement motor (M5).
      2) The link lever slides, driven by the rotation force of the cam.
      3) The pressure release lever rotates when the link lever slides, and the primary transfer roller
      for color is disengaged from the ITB.
      4) At the same time, the pressure release cam also rotates. The primary transfer auxiliary
      roller (right) moves up and the primary transfer auxiliary roller (left) moves down.
      5) The position of the primary transfer roller is detected by the primary transfer roller
      attachment/detachment HP sensor (PS5).
      <Related Error Codes>
      E074: Primary transfer roller detachment/attachment error
      <Related Service Mode>
      COPIER>OPTION>FNC-SW>T1HP-POS: determine the primary transfer roller engagement/
      disengagement HP
      <Related User Mode>
      Settings/Registration>Adjustment/Maintenance>Adjust Action>First Print Time>B/W Priority
      • Alex ahir
        • May 2012
        • 125
        no there is no image before transfer and another thing is its giving me the massage that waste toner is full i replaced it after certain black copies and color waste toner is full i check waste toner i found out that all waste toner is like a toner and its full within 1 hour. i changed all drums, main board but same thing. i checked primary rollers are lifting when i do PG10 it creats black image but all the colors are missing
        • Joseph2011
          • Aug 2011
          • 88
          Re: ADV 7055 giving White copy zzz
          ALEX:
          review the transfer unit, there is a newsletter where you asked to change all the transfer rollers and their bases, I send you the code then .... if you changed the rollers you might check out:
          - When no image of any color (C / MY / BK) reviews the primary charge corona color black and the internal connector is at the base of the team, that connector usually does cause arcing and white copies or spots all over and no image sheet
          - If you print only C / M / Y color black and nothing you have to change the sub hopper assembly, internally is broken toner contributor to its code: FM3-9895-000, FIRST REVIEW (This same problem happened to me and the sub hopper assembly was)
          regards
          • Alex ahir
            • May 2012
            • 125
            Originally posted by Joseph2011
            ALEX:
            regards
            thanks man,
            i will try and let u know
