Canon iR5570 Fax Kit
  • yus
    • Apr 2025
    [Misc] Canon iR5570 Fax Kit
    i've already installed a fax unit to the machine. but when i try to fax a document, it'll continuously failed. i'd setting inside the service mode with my country code but it still can't go through. i also had replace the fax unit with another but still the same. anybody know what had cause this?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 4987
    Re: Canon iR5570 Fax Kit
    Fax board model?
    Practice makes perfect
    If you want something done right, you have to do it yourself
    • yus
      Originally posted by zoraldinho
      Fax board model?
      my modem board is FM2-2789,
      • zoraldinho
        • Mar 2008
        • 4987
        Do you have super G3 -R1?
        In service mode, select FAX > Type > TYPE and make settings for country/region of the FAX board.This operation
        enables the parameter settings suitable for communication specifications of each country/region.(When I
        changed setting of it turn off/on the main power switch according to the shutdown sequence.
        Here, the minimum settings are made necessary for FAX communication.
        Basic settings
        - User telephone number
        > [Communications Settings] > [Fax Settings] > [User Settings] > [Unit Telehone #] > Input fax number >
        [OK]
        - Types of telephone lines
        > [Communications Settings] > [Fax Settings] > [User Settings] > [Tel Line Type] > Select the type of the line
        > [OK]
        Communication Test
        Carry out a communications test to see if the fax functions of the machine operate as expected:
        1) Bring up the Send screen on the control panel.
        2) Send a test original to a party capable of a communication test, and check to see if the original is sent normally.
        3) Send a text original from the other party, and check to see if the original is sent normally.
        • Herrmann
          • Jan 2006
          • 792
          Check, if your customer uses VOIP; if so, disable ecm and try to lower the modem speed, in addition you can try to set the country settings to "other" to open the tolerance window as far as possible
          If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
