CLC5151-H1 ( printing problem)
  • sgcopiertech
    • Aug 2025
    Hi, I need to configure CLC5151-H1 for printing, so I checked the Canon site for printer driver download
    CLC5151-H1
    and downloaded this two drivers (1 PCL, 1 PS)
    1) Canon PCL5e/5c, PCL6 Printer Driver v8.90 / v6.90 for Windows (32bit) (PCL5e/5c v8.90 / PCL6 v6.90)
    2) Color Network Printer Unit-H1 PS Printer driver v2.0 for Windows (v2.0)
    everything is working for the PCL driver, however, when printing using the PS driver, the document doesn't print-out, the machines processing/data light will just blink a few times but no document will print out.
    a check on the system monitor print log doesn't register any print / print error.
    I've attached the configuration printed out from the imagepass h1, I don't have much experience for this model, and found no clue when reading the H1 service guide & installation manual. maybe someone can point out any configuration issues.
    hope you guys can help thanks!
  • KL568
    _
    • Feb 2011
    • 324
    Re: CLC5151-H1 ( printing problem)
    Hi,
    Since you are able to use PCL driver to print meant that all your steps are correct.
    As to why PS driver not able to print, I believe it can't print cos your H1 is not Version 2 firmware (Line 4 of Server Info). Try to find PS driver Version 1 else you have to upgrade H1 to Version 2 in order to use the PS driver that downloaded of the web
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5018
      Reading material........acc-805.pdf
      Make sure Print to PostScript Error in Setup is set to Yes.
      Check for error messages on the Unit-H1 output.
      • sgcopiertech
        Hi guys, Problem solved
        PS driver Version 1 did the trick!
        thanks for the "notes" zoraldinho!
