IR 105 plus-paper jam
  • a.ghafari
    • Sep 2009
    • 46
    [Jamming] IR 105 plus-paper jam
    daer guys,
    I have some problem with canon IR 105+. paper jam in fuser with fault code jam (010B), half of paper A4 in left side of fuser and half in right side. I had this fault in xerox 4110 in that case there was problem in heatroll bearing. I changed fuser module/inverter module/ sensores like s9...
    I am Xerox technecian so I have not exprience in Canon please give some advices.
    Thanks.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Re: IR 105 plus-paper jam
    Check GEAR, 52T ......... FS7-0007
    • a.ghafari
      • Sep 2009
      • 46
      Dear Friend,
      I checked this gear and there is no problem. also I changed fuser Ass. with another one but unfortunately the fault is still. I think maybe fuser drive mot. turn slow but I have no one to test it. sometimes this fault is intermittent. I will be appreciate for your advice.
      • zoraldinho
        • Mar 2008
        • 5018
        Inspect Inside delivery sensor (PS9).I can't post a location picture at this moment.
        • Paul 75
          • Oct 2008
          • 97
          As Z said, check the internal sensor arms for paper burrs.. this happens alot on high volume machines. Also :
          Check that your fuser bushes are on correctly ( both inside facing out ) and your black double gear and the fuser drive motor teeth at the front. I've had both of these fail regular.
          Oh...... I can't copy at the moment then ? !!!!!!
